Salta al contenuto principale
A1708 / EMC 3164 — Lanciato a giugno 2017, questo MacBook Pro entry-level conserva i tradizionali tasti funzione (invece della Touch Bar OLED.
Screen lines vertical and horizontal even on external display
I have a macbook pro 2017 non-touch bar.
Today I started up with all these screen lines and glitches. Until now i tried to reset pvram and smc but not worked at all. Even I tried to "safe boot" or diagnostic tool from apple but not detect anything an the problem still goes.
Please someone can help me!!
Thanks so much,
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
This tearing effect is a scan issue within the T-CON unit which is part of the display assembly. You'll need a new display assembly MacBook Pro 13" Retina (Late 2016-2017) Display Assembly and here's the guide Sostituzione gruppo schermo MacBook Pro 13" Function Keys 2017
Immagine Replace a display compatible with a 2016 or 2017 model A1706 or A1708 MacBook Pro 13" Retina laptop. Includes the 2560 x 1600 13.3" Retina LCD Screen, Display Cover, Bezel, FaceTime HD Camera, Clutch Hinges, Display Daughter Board, Cable Spring Mechanism. Part #661-05096.
Prodotto
$444.99
Punteggio 1
Risposta Più Utile
Hi
If it’s showing it on a external display that would lead us to believe that your gpu is failing but on onboard graphics that’s very very rare
I would ether update it or bring it to a apple store just in case it’s a known software issue
But if we diagnose it and it’s the gpu you will probably have to replace the logicboard as replacing the cpu(gpu is part of it) really isn’t practical for anyone who isn’t doing these sorts of repairs frequently
Hopefully this helps
Any questions please ask
Punteggio 1
Aggiungi la tua risposta
RRS sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 722
