Salta al contenuto principale
Rilasciato a luglio 2018, il MacBook Pro da 15", modello A1989, adotta uno schermo retroilluminato a LED da 15,4" con tecnologia True tone, Touch ID e processore fino a esa-core Intel Core i9.
Keyboard backlight not working
Hi. all
i had to detach my MacBook pro 15 " 2018 (A1990) screen because it was broken.
The keyboard backlight dies not. work anymore.
Did I mess something. up or the backlight cable is connected. to the screen?
Questa è una buona domanda?
Punteggio 1
4 Commenti
Here is the photo[image|2712864][image|2712867]
da
@wael - Can you show the ribbon cable for the backlight?
da
I just need to know if the keyboard backlight is related to the screen being attached? Meaning that when I remove the screen from the lapto like in the above photo. Will the keyboard backlight work?@beanman56
da
@wael - It doesn't seem like that would be the cause
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
If your screen is no longer attached, the reason your keyboard backlight does not work anymore is likely because your computer can no longer communicate with the ambient light sensor. The ambient light sensor is part of the system which sets the auto brightness for both your display and the keyboard backlight. Without this data the device just removes this functionality. You may still be able to adjust the backlight settings manually using the Touch Bar. But I have see occasions where it won’t work at all in this case.
Punteggio 2
2 Commenti:
Well Said! :-)
da
Yeh , That is what I figured out after some googling.
but the whole thing is working perfectly except for the backlight and the chime at startup ( which is weird ). but. I am ok with that. itis a small tradeoff :D
da
I am talking about MacBook Pro 15” 2018 A1990
And I am talking about the keyboard light.
It sure has, I have been using it for years, there must be an understanding somewhere :)
Punteggio 0
3 Commenti:
You said Core 2 duo 13" in the question
da
My model was not in the list :)
da
@wael - Hmm, I think it is
da
Aggiungi la tua risposta
wael sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 17
Tutti i Tempi: 951
