Salta al contenuto principale
Lo Huawei P8 Lite (Modello: ALE-L21), annunciato nell'aprile del 2015, punta sulla bellezza nella semplicità. Le sue fotocamere professionali permettono di scattare foto naturali e nitide anche in ambienti poco luminosi. La modalità beauty abbellisce il viso del proprietario in ogni selfie.
Weak GSM signal indoor
After I took my phone in for repair charging block my Huawei P8lite Have Bad signal then it shows Emergency calls only or No Service But at Certain Spots it Finds A little bit Signal in bathroom Only H+ And in town it gets 4g Its signal is very bad... Before I took it in for repair I didn't struggle with the signal it was 100% working... After I took it in for repair the charging block I struggle with the Signal. I did take it back to them they check what's wrong they said they accidently broke my Anthenna /signal Anthenna they show me it is a Small silver thing... They repair it For free they said because they broke it... But Nothing changed.. Still struggling no service or Emergency Calls only... Please I need Help
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Take it back. What did the part look like? A tiny ring? Also is it from the bottom or the top of the phone? If it's from the bottom they can fit a complete speaker assembly which has the antenna connection on it. If its from the top they need to solder on a new connector, unless they ripped off the pads in which case they would owe you a new phone.
Punteggio 1
Aggiungi la tua risposta
Estie Botha sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 129
