Salta al contenuto principale
Questa è la versione con modulo LTE della quinta generazione dell'iPad, ed è stata rilasciata nel marzo del 2017. Nasce con il processore integrato A9 a 64 bit, uno schermo Retina da 9,7'' ed è disponibile in una versione da 32 e un'altra da 128 GB di memoria e un processore A9 da 64 bit.
Panic (cpu 0 calller) after battery repair
Did a battery repair on iPad 5 Cellular. After customer left with ipad it began to boot loop every 3 minutes. Shows PANIC (CPU 0 CALLER). I have already replaced the charging port but still the same issue.
Any ideas?
Thanks
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Risposta Più Utile
This is likely some issue with a sensor checking in. This is almost always the case after a battery repair. It’s possible the new battery is defective. Or the battery connector on the board sustained some damage during the repair. The data pins in particular are prone to bend.
Can you post a copy of the full panic report? Or at least screenshots of the first page or so?
Punteggio 2
2 Commenti:
I have a picture of the panic log below
da
@store0667 The panic you posted indicates pretty much what I expected. There is a battery sensor (TG0B) which the iPad is not getting communication from. The issue is going to most likely be the new battery, or damage to one of the pins on the battery connector. I would recommend taking the board out to inspect the underside of the battery connector.
da
Here is some of the Panic log.
Thanks
Punteggio 0
1 Commento:
How did you disconnect the battery before disconnecting the screens? Or what did you use? Does as mentioned before sound like damaged pins on the board. A pain but remove the board completely and take a look for damage.
da
Aggiungi la tua risposta
BP 667 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 22
Tutti i Tempi: 1,055
