Hi Alex,
My personal vote would be no, don't use regular double-side tape. While it will get you through this repair and most likely be satisfactory for continued use of the machine, it'll be nothing but headaches the next time you need to remove the battery.
The stretchy Command-style adhesive is meant to be (fairly) easy to remove and is very sticky, so using a replacement that gives the same holding power will mean it'll be a major pain in the behind to get the battery out again.
With regard to reinstalling the battery, yes, virtually all of the guides on iFixit assume that the install procedure is simply the reverse of the removal, so you just follow the guide again in reverse order to put everything back the way it was.
Don't forget to follow the instructions in the final step to calibrate your new battery once it's installed. The one step that looks like it's missing from the guide is in putting the adhesive down for the new battery. The adhesive strips go on the battery itself, with the ends wrapped over the edge of the battery so you can get to them once the battery is in place. Dry fit it before remove the covers on the adhesive and make sure it's properly placed before you remove the plastic. Once you set it down, it's going to be stuck good, so be sure to line it up right before pressing it in place.
Best of luck with your repair!
Votato
Annulla
Punteggio
2
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
