Salta al contenuto principale
Smartphone al top di gamma Huawei lanciato nell'aprile 2019. Caratterizzato da uno schermo OLED da 6,47" FHD+, sensore impronte digitali integrato nel display, fotocamera principale da 40 MP con teleobiettivo da 8 MP e da una nuova tecnologia per l'altoparlante voce. Modelli VOG-L29 and VOG-L09.
P30 Pro under a car. Possible recover data by chip off?
Hi everyone, I have a Huawei P30 Pro destroyed because it finished under a car. Mother board is a bit damaged, like fpc connectors, display is totally destroyed. Is possible recover data by chip off method? Or I'm obbligated to buy a new or used screen after repairing fpcs connectors). Client wants to recover photos. He didn't have a Google backup of these photos. The phone has lock screen too.
Salve a tutti, ho un Huawei P30 Pro finito sotto una macchina. Possibile recupero dati con il metodo chip off? I connettori fpc sono danneggiati, così come il flat di ricarica che va dalla main board. Il telefono ha pure il blocco schermo.
Update (07/31/2022)
Hi, yes but screen is destroyed and there is screen lock.
fpc flat is broken, I must hold it in one precise position to make smartphone recognize. In truth pc try to recognize it.
Questa è una buona domanda?
Punteggio 0
1 Commento
does it connect to a pc ?
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
you can get an otg hub, it will mirror whats on the screen to a monitor/tv and you can connect a mouse and keyboard to use the phone and backup data that way
Punteggio 1
2 Commenti:
but debug USB mustn't be activated? I'll try. Thanks.
da
@shinobi76 im not sure about debug usb, i havent tried it myself yet. i ended up ordering the wrong hub for future recovery so i need to order the correct 1
da
Usb debug must be turned on to access the phone via usb. Nobody has it turned on as you have to enable developer options to get to it. You might be able to back it up via adb if the usb isn’t shot too.
Google adb for the phone as there’s lines lines you have to type into adb which you can copy.
Punteggio 1
Aggiungi la tua risposta
Rosario Mangiagli sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 10
Tutti i Tempi: 282
