Recently replaced dead GPU and now my iMac restarts seemingly randomly
My mid 2011 27 inch iMac had GPU problems which I solved with oven baking the card but came back three months later. I opted to buy a replacement GPU purchasing a 109-C29657-10. I noticed some small differences with the text on the card but I figured that was a newer revision of the card. Installation went well but after reassembly my iMac fails to stay powered long enough to boot to macOS. If I boot into recovery mode it can stay on for hours but the moment I try to boot into macOS it power cycles. I have taken it apart and put it back together multiple times. I am at a loss. Any help is appreciated thank you!
Update: Sadly purchased a bad GPU off ebay. Resorted to re-baking my old one and it fixed it for now.
Questa è una buona domanda?
10 Commenti
Have you tried booting into safe mode?
Also did you make sure the gpu was compatible?
da HelloMacOS
@hellomacos I was never able to get into safe mode might been because I did a fresh install of High Sierra but cannot actually set the Mac up. As for compatibility I took the exact same part number is there a better way to check?
da Logan
@logan2001
Aslong as it’s supported through the machine it should work
da HelloMacOS
@hellomacos Yeah I believe the GPU is working fine, I just cannot stop the constant restarts.
da Logan
@logan2001
Have you tried reseating it in the computer?
da HelloMacOS
Mostra altri 5 commenti
