Salta al contenuto principale
iPhone di quarta generazione. La riparazione è semplice, ma il vetro anteriore e l'LCD andranno sostituiti insieme. GSM / 8, 16, or 32 GB di memoria / Modello A1332 / Nero e Bianco.
battery replacement for iPhone 4 shown on iFixit
I watched a video by iFixit on changing the battery. The girl in the video took off an antenna contact and put it aside. What does that contact do? On the video she does not show her replacing it. I have not yet done so yet the phone functions receiving a message. It is a bugger to replace [with arthritic fingers].
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi
I believe the contact is for grounding purposes
All you have to do to put it back on and align the hole with where the screw goes back in then plug your battery back in on top of the antenna
So the screw should go through the metal bit on the battery connector and go through the little metal loop on the antenna
If you need any more help just ask
Hopefully this helps
Punteggio 1
Aggiungi la tua risposta
william heilman sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 50
