Salta al contenuto principale
Entry level business laptop introduced by Dell in 2014. Uses Intel Haswell (4th generation) processors.
15 Domande Visualizza tutte
Laptop not turning on.
My laptop is not turning on, I've charged it for 2-3 hours but the indication light frequently blinking and laptop not turning on.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
First unplug charger and take out the battery. Now just plug in the charger and see if your computer turns on.
Here are the Battery Status Lights:
If the computer is connected to an electrical outlet, the battery light operates as follows:
  • Alternately blinking amber light & white light--> Unauthenticated or unsupported non-Dell AC adapter is attached to your
  • laptop.
  • Alternately blinking amber light with steady white light --> Temporary battery failure with AC adapter present.
  • Constantly blinking amber light--> Fatal battery failure with AC adapter present.
  • Light off--> Battery in full charge mode with AC adapter present.
  • White light on--> Battery in charge mode with AC adapter present.
What matches what you see?
Try slide
Punteggio 3
Aggiungi la tua risposta
Neeraj sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 22
Tutti i Tempi: 997
