Salta al contenuto principale
La Passat B6 venne presentata per la prima volta al Geneva Motor Show a marzo 2005 e lanciata in Europa nell'estate del 2005.
20 Domande Visualizza tutte
Right tail light won’t work
So, I have a VW Passat B6 2007. My rear right side tail light, day time running light stays on for a few seconds before it turns off. Now I don’t find the solution, and trust me I have tried. When turned on it starts to blink and then it turns off, I tried to put 12V directly on to the light and it worked perfectly. Please Help
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
It could be a corroded or broken wire perhaps even lose wire
Make sure bulb is all the way in and turned and inside connections or contacts are not corroded
Punteggio 0
Aggiungi la tua risposta
simonrk sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 170
