Salta al contenuto principale
Repair documentation for the Fitbit Versa 2 smartwatch. Released in September 2019.
My Fitbit won’t charge
My Fitbit is dead and it won’t take a charge what can I do
Questa è una buona domanda?
Punteggio 4
1 Commento
When i purchase my watch after it never charged what should i do
da
Aggiungi un commento
3 Risposte
Risposta Più Utile
Hey, it depends on whether its not charging or if its not taking a charge.
If it is showing that its charging but after unplugging it you see that its not taking charge its very likely to be a battery issue. To solve that you would need to replace the battery(Available for many of the fitbits) but this requires some technical abilities.
If its not charging at all there is a vast amount of possibilities of what could be wrong but you could attempt to clean out any debris from the charging connector on both the watch as well as the charger.
Punteggio 1
I Have a Versa 2 and was facing the same issue but Thankfully I have got a solution which was fixed it.
here are few of them that worked for me and a several other on a detailed post.
Punteggio 1
You have to sync it to the fit bit app..once u do that it will update the time etc
Punteggio 0
Aggiungi la tua risposta
Susan Scheidt sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 57
Tutti i Tempi: 5,659
