Salta al contenuto principale
Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
Display LCD chips overheating
After replacing a cracked digitiser screen the chips at the bottom of the LCD display are getting very hot during use, I estimate 40 - 50 oC and eventually the digitiser loses sensitivity. It cools down when no apps are being used and is then ok. It takes about 30 minutes of game play to get hot. Any suggestions welcome.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
It doesn’t sound like a problem to me, seems to be expected behavior.
Punteggio 0
3 Commenti:
Thanks, but I didn't expect it as it didn't happen before I changed the digitiser screen. Is it normal for the screen to lose all touch sensitivity after 30 minutes?
Regards
Bob
da
@bob_pluck losing sensitivity shouldn’t happen, but your description is too vague to tell for sure. Which chip is overheating?
da
The row at the bottom rear of the LCD display. Highest temperature at the cable end of the strip.
I have tried to attach an image but not sure if it has worked.
da
Aggiungi la tua risposta
Bob Pluck sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 83
