Optical drive connector capability
If I were to use an SSD with the optical drive connector as a primary drive (running the OS), would it run as fast as if connected through the regular cable?
Questa è una buona domanda?
Mactracker database shows both the hard drive and superdrive are SATA 3, supporting 6Gb/s as max speed for your model. It shouldn't be a problem to use the superdrive connector for the main drive, as far as speed is concerned.
thank you for your answer
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 34
