Salta al contenuto principale
Slightly loose side panel
My side panel on the brand new Aerox 5 wireless is slightly loose. It is barely visible with the naked eye, but you can feel it during gaming as you grip the mouse and move around - it is kinda annoying.
Does anyone has the same issue or know how to fix that? I think that it may be fixed just by tightening some screw inside but haven't opened the mouse yet - since I did not find any teardown online even for Rival 5 that has the same body (to be safe - not used to modding like this).
I am attaching the example of what the issue sounds like since it is barely visible in person :)
https://youtu.be/PKzMLFvvDh8
https://youtu.be/F5WX_Woki84
Thank you for any reactions.
UPDATE:
I have inserted a piece of paper to reduce the clearance and it seems to work.
Going to get some black paper from my local store and trim it to blend in as a temporary solution until the teardown/disassembly tutorial comes out.
Immagine
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Timeline 4:30 of this video will show you how it fits together so you can see the inside:
https://www.youtube.com/watch?v=BVFyvOM3...
Punteggio 0
1 Commento:
Thanks for the submission. However, the mouse that is shown at 4:30 is Razer Naga Pro - which won't help me here with Aerox 5 disassembly.
Nevertheless thanks for trying to help.
da
Have you managed to fix this issue?
I have exact same problem.
Punteggio 0
Aggiungi la tua risposta
Tomáš Dohnal sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 12
Ultimi 30 giorni: 63
Tutti i Tempi: 2,390
