Hi have a dc44 dyson and the main body has started to make a noise
Hi have a dc44 dyson and the main body has started to make a noise and blowing a lot of air from it, can these heads be fixed or sent away for repair ?
Questa è una buona domanda?
Hi
The parts can be sent away but in my opinion it’s not worth sending away as these issues are easily fixed
I had a similar issue with my dc50 and it was the cyclone that was the issue
But my recommendation is just to take it to bits roughly and give everything a good shake and that usually fixes things
If that doesn’t work try taking the full thing appart(except the motor Handel assembly) and give everything a good clean with a brush and a damp cloth
Hopefully this answers your question
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 75
2 Commenti
I assume that your reference to 'the main body' refers to the handle with the motor in it. is this correct? Does it still make the noise if you remove the pipe and the tool on its end? I am just wondering if the pipe is blocked!
da Alan
In addition to checking for clogs, be sure to clean the removable filter.
da Christopher Sean Harris
