turns off immediately when running on battery with blades attached
Trying to diagnose Conair HCT7565RLIC trimmer turning off immediately when running on battery with blades attached only. Runs without blades on battery, or with blades when plugged in to AC
Battery appears to be fully charged, but it only runs for about 1 second when turned on each time you flip the switch.
Disassembled to try and identify the cause, discovered it will run without the blades attached, left it running for quite a while to test the battery; the moment there's pressure on the motor from the blades fully secured it blinks red and shuts off.
When it's run off AC power directly, it runs just fine.
Questa è una buona domanda?
