My right side headphones is not working?
my right side of the head phone is not working
Questa è una buona domanda?
Tanvi Snayal first check your accessibility settings (settings - general - accessibility) to make sure the volume is balanced between both sides. Anything after that is most likely a bad ensure the volume is equally balanced between both left and right sides. If all that checks out okay, you want to do a reset
1. Turn your headphones off.
2. Enter pairing mode by pressing and holding the volume+ button for 5-7 seconds. Your headphones will turn on, and then the LED light will flash red and blue.
3. Press and hold the multifunction button, volume+ button and volume- button simultaneously for 3-5 seconds. You'll hear beeps and/or feel vibrations.
4. Turn your headphones off.
Your headphones are now reset and can be re-paired to your device.
Anything after this would require a teardown and possibly replace the "speaker". Definitely not a fun thing to do but it might be possible Aftershokz Trekz Titanium Teardown
Ultime 24 Ore: 13
Ultimi 7 Giorni: 67
Ultimi 30 Giorni: 365
Tutti i Tempi: 7,528
