Salta al contenuto principale
La versione rilasciata nel maggio 2020 del MacBook Pro da 13" si caratterizza per i processori quad-core Intel i5 e i7 di 10ª generazione e per la grafica integrata Intel Iris Plus (modello a2251/EMC3348 con quattro porte Thunderbolt 3).
open board view not working as expected
hi
I was looking a a board view in openboard views and went to flip the board to see the other side but it just disappeared
do some schematics just do this or am I doing something wrong because I was using the flip board from within a menu
it will be greatly appreciated if someone can point me in the right direction
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
Soluzione Prescelta
@hellomacos when you close your openboard viewer and then restart and open the same boardview, does it display it again? I am having the same challenges on some .BDV files and it is the viewer program. The image is still there just not centered on the display but it is all the way "North". It's off the screen :-) to the top
Punteggio 1
2 Commenti:
Hi @oldturkey03
Just tried looking up north as you said and I worked at treat
Thanks soo much this is a total life saver!
da
@hellomacos glad it helped :-)
da
Aggiungi la tua risposta
HelloMacOS sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 12
Tutti i Tempi: 560
