Salta al contenuto principale
La versione allargata del decimo telefono di Samsung della sua serie top S, presentato nel febbraio 2019. Dotato di Android 9.0 (Pie).
20 Domande Visualizza tutte
Replacement Screen kit compatibility
Hi, I would like to know if the replacement screen on the iFixit kit compatible with Samsung Galaxy S10+ Interntional models?, i was told at an Authorized service center here in Canada that there are compatibility issues with replacement screens of Canadian models and International models. I would greatly appreciate any help.
Thank you!!
Questa è una buona domanda?
Punteggio 2
1 Commento
I am currently experiencing the same issue on my Samsung S10+ SM-G975U
I bought a replacement screen.
But seems it's not compatible.
It works sometimes after a while it freezes and won't respond until you lock it and unlock it sometimes I've to perform this task several times for it to be responsive again.
Once it works, works normal no problem until after a few minutes and starts acting the same way.
If there's any solution without changing the screen please help.
It's annoying 😒
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Jeff Carreon I have not seen or heard that one but you do want to make sure that you order based on your model. For the S10+ the versions are SM-G975F/DS (Global); SM-G975U (USA); SM-G975W (Canada). I suggest that you contact iFixit Support by any of these means and see what they can tell you. On here we are mostly volunteers that are not directly involved with iFixit sales.
Punteggio 2
Aggiungi la tua risposta
Jeff Carreon sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 322
