Why Is My laptop very slow
Laptop is very slow although it's only 60% drive full
Questa è una buona domanda?
1st: You have an I3, which means if your multitasking it's going to be slow.
2nd: If you have 4GB of RAM, I suggest you get 8GB of RAM to speed it up a little.
3rd: If you have Windows you can go in disk defrag and speed it up a bit.
4th: If you have Windows you can go into settings and change the apps that start up when you boot the laptop.
5th: If you get an SSD you can speed it up just a bit.
4GB of system memory is totally inadequate. Replace the 4GB SODIMM with a 16GB SODIMM.
It may be thermal throttling,. If it's in a dusty environment, exposed to smoke, etc. this can happen relatively quickly. Check that your fan is working and not full of lint, dust, fur or what-have-you This includes the air inlet grille on the bottom and the radiating fins on the back in particular (the fins are delicate, be careful) check for any leak on the copper heat pipe. Is anything blocking your airflow into or out? Are there obstructions to airflow? (What surface is it on,. Can air enter and exit for cooling)you might Install speedfan (its free) or something similar so you can see the temps, fan speeds and figure out what, if anything, is overheating as well as configure your cooling or use whatever software you prefer to achieve that. Assuming a good cleaning and good airflow didn't work it will be time to consider hardware issues beyond cooling. Replacement of thermal paste might help if it is more than a year old... otherwise the diagnostic. Information from speedfan should make troubleshooting a little easier in future. You can find that at https://www.almico.com/sfdownload.php Now, that is only one possibility, Despite having antivirus, it remains a possibility, none of the antivirus software are perfect. Try scanning with a different anti-virus, follow instructions to avoid cross detection issues. There are also other possibilities to look at,. But I d start with this and if that doesn't fix it holler for more help, OK? While the answer above may be correct, without your model it's not necessarily correct,. Specs on this series vary (drastically) as does available OS. Unless it shipped with all top of the line options the memory, nvme SSD and data drive bay may be upgradeable though the GPU and CPU and one memory bank are soldered to the board and are thus not upgradeable. Note: Don't defrag a solid state drive; which you may have, it isn't necessary and shortens it's life
It's probably full of viruses I would take it to a computer shop and have it cleaned out.
I have Antivirus software as well. There were no virus found
Windows has windows defender. Ive heard good things about it. There are some bugs that can bypass and even hijack the antivirus.
Ive dealt with one that prevented me from running any software for malware. AntiMalwareBytes actually. Its an excellent program. Will definitely detect more than most paid antivirus
Ultime 24 Ore: 3
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 105
Tutti i Tempi: 3,849
