Salta al contenuto principale
Modello A1136 con 30, 60, o 80 GB di hard disk con plastica frontale bianca o nera
798 Domande Visualizza tutte
I broke the clip for the headphone jack connector, what do I do?
The flip down clip for the headphone jack connector on the mobo broke off. Can i just use kapton tape or something to keep it in? If not, how do i replace it?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
@coopbossman tape will not close the contacts. It needs that little bit of pressure from the clasp. Depends on how and where it is broken, sometimes you can reinsert the clasp. If you can't get a broken board and harvest the connector from that. It is soldered and as such you will have to desolder from the old board and then transplant to your board.
Punteggio 2
Aggiungi la tua risposta
Cooper Quintrall sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 38
