Salta al contenuto principale
Lanciato il 22 settembre 2017. Modelli A1864, A1897. Disponibile in versioni GSM o CDMA / 64 o 256 GB / gold, silver e space gray.
678 Domande Visualizza tutte
Display touch stop working when home button flex is connected
Hi. So i recently opened my iPhone 8 Plus to replace my battery. Before I opened it up, the touch id was already not working and the home button was working intermittently but the 3d touch and normal display touch was working fine. However, after opening it up and reconnecting the flex cables, the touch only works if the home button flex cable is not attached. Once i attach the home button flex cable, the home button starts working but touch stops. I have to mention that the home button flex cable also seems very loose and I have to attach the metal bracket to keep it in place. What on earth is going on?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
The most common cause for this problem on the 8 plus is a stretched home button connector. This happens after trying to fit a 7 plus screen in the past. There are four ground pins on the logic board home button connector which are located on the ends. I usually find the ones on the (right) have been pushed into the plastic and need to be pulled out and the rest of the connector squeezed in with tweezers. To pull the ground pins out you will have to use magnification and a tiny utensil. I usually use 0.01mm wire.
Punteggio 2
2 Commenti:
Update: So I tried my best to pull back grounding pins with the help of a phone’s camera to see… well the touch and home button started working together once after multiple plug in and removal of the flex cable. Then I realised I didn’t put the adhesive in… so I unplugged it and the home button never worked again after that. I assume there is a short somewhere in the home button connecter. Guess I have to live without the home button or 3D Touch, unless I take it to a professional repair shop and fix the short… TLDR: fix the ground pins with an actual magnifying lens
da
You can get a replacement home button it will work but you won't have touch id
da
Aggiungi la tua risposta
InfernoWolf19 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 16
Tutti i Tempi: 327
