Salta al contenuto principale
Samsung's third iteration of the Galaxy Watch with a newly integrated BioActive Sensor. It was released August 27th, 2021. Model SM-R860, 40 mm, non-LTE version.
Where is the NFC antenna?
Unlike Apple Watch, where you present the face for NFC payment, the Galaxy Watch 4 seems to require something else. Presenting the face sideways is a bit better.
Where is the antenna and how should I present the watch to ensure best chance of payment being accepted?
Thanks
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Hello.
I found this solution from a site: You tap the top edge of your watch toward the NFC reader on the register/terminal you're using.
(https://www.androidcentral.com/how-set-s...)
Punteggio 1
2 Commenti:
Thanks. I've been presenting the edge, which mostly works. However, my watch is oriented for left-handers. So I guess it's the bottom edge?
I'm going to change the orientation to see if the top edge (from right-handers perspective) is better.
da
Glad I could help!
da
This may help others diagnose the problem.
I saw a comment somewhere about using an Android app called NFC Reader. It has an option to "Scan a Tag", which, once tapped, will display NFC information about the device/card presented to it. That seems to work with both the bottom and top edges for the GW4.
I've noticed that sometimes I have to continue to hold the watch to a reader in a shop and the phone buzzes twice: the first attempt is rejected and the second accepted. I just did the same with NFC Reader app. The first attempt shows a lot of strange characters but the second is parsed correctly by the NFC Reader app. The GW4 NFC technology is shown to be "IsoDep, NfcB". I assume there are different signal types/standard?
That may explain why some readers say present one card only when I use the watch to make payment. From searching, this seems to be a firmware fault in those readers. My guess is the watch is sending two NFC signals to readers to allow for different standards?
Punteggio 1
1 Commento:
I think I found the solution to this problem. The unknow character from the first scan is due to samsung health app. Go to NFC settings -> Others -> toggle off samsung health. After this, every scan will be correct.
I tried this and after this I did not see any unknown scan on the NFC reader app.
Refer this thread for similar issue - https://www.reddit.com/r/GalaxyWatch/com...
da
Aggiungi la tua risposta
Praful Kapadia sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 33
Tutti i Tempi: 4,129
