Salta al contenuto principale
Processore quad core Intel Core i7 da 2,2 GHz (3,4 GHz con Turbo boost), 2,5 GHz (fino a 3,7 GHz con Turbo boost) o 2,8 GHz (fino a 4,0 GHz con Turbo boost) con 6 MB di cache L3 condivisa.
battery not detected PPT001
I have bought an iFixit replacement battery, installed it, 3 days after delivery. The battery symbol is crossed out. I have reset the SMC and PRAM there is no change.
The battery is connected, as clearly the computer is not totally dead with no power adapter. It is able to show "battery not charged" symbol when I try to turn in on without the power adapter. When I disconnect the power adapter after the computer has booted into the OS, the screen goes dark immediately, but after I reconnect the power cord it seems to have successfully hibernated.
The diagnostics tells PPT001.
And I actually have solved the problem, decided to share the experience, as this may help others. The reasons for all above was that battery connector was not fully pushed into the socket. Some of the pins of the socket are "shorted" and they likely have not been connected. So while "power" part of the battery was there, the "control signals" likely were not all making through.
When viewed from the side there should be no gap between the socket and the battery connector.
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
3 Risposte
Soluzione prescelta
Punteggio 1
1 Commento:
Thank for for posting this. Solved my problem exactly
da
Hi
I have the same problem. When you say the battery connector wasn't connected properly, do you mean the flimsy ribbon connector that goes across the top of the battery? Thank you.
Punteggio 0
I've had this problem for abt 3 years. My computer only works with the charger in and I've already had it replaced and unfortunately don't have the money to get it replaced or buy a brand new computer. I saw the gap and pushed it in and it still hasn't fixed my problem. Any other solutions?
Punteggio 0
Aggiungi la tua risposta
Mateusz Lacki sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 6
Ultimi 30 giorni: 40
Tutti i Tempi: 4,785
