Salta al contenuto principale
Il tablet Amazon Fire HD di 7ª generazione è stato rilasciato nel giugno 2017. Da allora è stato ritirato dal commercio e sostituito dall'attuale versione del Fire.
Cracked LCD and touch screen on Fire 7 9th generation
I got REALLY upset and destroyed the screens of the tablet. The digitizer, LCD everything. I found a new screen for it, and I want to buy it! But here is the problem, I have no tools! Are there any household items that would work for any tools I would need? Thanks! -Blackcomb
Questa è una buona domanda?
Punteggio 1
2 Commenti
Indeed! you could use a hairdryer to loosen the LSD Tweezers for any inside work. But a wedger is needed along with a suction cup
da
my screen is not responding it still works it just don't take input
da
Aggiungi un commento
1 Risposta
Risposta più utile
@blackcomb there really is no good substitute for the right tools. All you would need is a set of small screwdrivers and a couple of guitar picks to remove the screen from the case. You could use a good hair dryer to loosen the LCD. All of that should be relatively easy to come by. This shows how to replace the screen.
Punteggio 1
1 Commento:
Maybe even trying to pry it open with your hands. **CAREFULLY**, though.
da
Aggiungi la tua risposta
Blackcomb6.1 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 34
Tutti i Tempi: 1,722
