How to change rear battery cover?
I want to change the rear battery panel because it's got some using marks and looks really bad
Questa è una buona domanda?
ybo.shooter check this video you need a heat gun as your main tool. Temperature on the back cover should be around 70deg C to loosen the adhesive. Not complicated just a bit tedious.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 488
