Salta al contenuto principale
Repair guides for cameras of the now-discontinued Minolta line.
103 Domande Visualizza tutte
*Minolta Maxxum 2800AF* Flash not turning on
I have a Maxxum 2800 AF flash I got with a Maxxum 7000 and 100-200 (1:4.5) lens. The camera worked perfectly, but the lens needed some work (AF gear was stuck, which I fixed by taking the rear lens plate off, letting it spin w/o the rear gear on the lens in the way, and coaxing it manually with a flathead) and the lens and camera have both been perfect. However, the flash has never worked. I'm not getting rid of the rest of it over a dead $15-20 flash, especially with the lens is worth as much as I got it all for. I'd rather discard the flash and keep the working lens and camera. The flash is so dead, not even the test button fired.
I have tried reseating the flash a few times, and it just does not work. I used 4 brand new AA batteries as well, so I know it is not the batteries in the flash. I also tried to clean the contacts in the flash (no corrosion, so denatured alcohol was used), and the situation did not improve. That said, while these were new batteries they are from Costco (that is to say, stockpiled) but were not expired. I did change the Jobsmart (TSC) AAA batteries I got with the camera ("batteries not included") with new ones, and neither set changes anything. The TSC batteries also tested good on my analog multimeter.
NOTE: The flash has a connector on the front that interfaces with the camera, but the cable is not required for the Maxxum 7000; it communicates solo -- I suspect it's meant for high-level communication with the vintage ones, or higher end cameras.
Is there anything I can do to verify the flash isn't dead, or is it just not worth messing with?
UPDATE
Tried brand new primary Lithium batteries, the flash is still dead.
UPDATE (3/18)
However I did notice one of my 7000's (one from a lot with a Maxxum 5/other for the lens with the flash) and the lot 7000 was not treated well in 2 ways: the mirror is pitted, and I had to clean battery acid (normal for the AAA cover due to storage neglect so I overlooked it). I'm going to relegate that suspect 7000 due to parts unavailability and see if it works on a 7000/9000 that was well used and taken care of.
UPDATE (3/19)
I opened the flash up after finding out how, and I cannot see any obvious faults on it.
I took a closer look at the main board and this area seems to connect to the button. Everything checks out so I think it's a component soldered to the board.
Questa è una buona domanda?
Punteggio 0
3 Commenti:
@oldturkey03 can you see if you can find a service manual for this flash? I suspect the capacitors, but couldn't find a way in.
New AAA batteries did not help, so it's not the camera.
da
@nick I'll check on it. Try to see if danj can fix you up. I think he is really into photography and photographic equipment as well.
da
@oldturkey03 I at least want to try before I give up on it. At least it won't be in vein, especially with the lens being repaired, which is arguably the best part of the set as well as the body (the newer Maxxums are better, but this still holds its own).
da
Aggiungi un commento
1 Risposta
Do you hear any sound when you turn the flash on? The inverter makes sound due to magnetostrsiction of the transformer. If you don't hear that, you're not to first base.
Unfortunately, Fixing this requires some electronic troubleshooting skills, and also precautions due to the high voltage involved. You could get lucky and find a bad switch, or a broken wire, but it will likely take more than that. If you can find a schematic for it and have the skills, then give it a try.
Also, you should stop using alkaline batteries in your expensive equipment. NiMH have several advantages, some of those being cost-saving, but the biggest of all is that they don't leak, whereas alkaline are guaranteed to leak. It's not that it's impossible for NiMH to leak, but I've never seen it in 15 years of NiMH use. I lost some expensive equipment to alkalines, before I wised up.
I recommend Panasonic eneloop cells and a decent smart charger. If you use high-intensity flashlights, you should get a charger that will also charge the lithium cells for your flashlight. They're readily available
Punteggio 0
2 Commenti:
@ffixitwell I used them for testing at most, and I will be using Primary Lithium for day to day use nor did I expect batteries with the 7000 with the lens and flash (but yes, I removed them). But yeah, this flash just sounds totally dead like it isn't even firing up at all. The previous owners of the cameras do that with alkaline, not me. I wouldn't trust those things in a SLR, much less a remote.
I think it may be toast, sadly.
I think the free batteries were from this year since they expire in 2026, and the shelf life is usually 5 years today.
da
Tengo un Flash Minolta 2800 operativo, para poder ayudarte tendrías que tener un mínimo conocimiento de electrónica, un multitester y saber usarlo.
da
Aggiungi la tua risposta
Nick sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 15
Tutti i Tempi: 634
