Controller arm band came out
My controller arm strap came out. How can I reattatch it
Questa è una buona domanda?
Alright, here's how you reattach it:
Open up the battery compartment. At the very bottom of the controller, there should be a small hole. You see the little plastic bit on the end of the strap? Pop that into the hole in the controller so that the strap is coming out through the bottom of the controller, put the battery compartment cover back on, and you're good to go. If the strap is actually broken, you can also buy replacement straps from Oculus.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 44
Tutti i Tempi: 698
