Salta al contenuto principale
A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
Retrieving documents from another computer
I have a custom-built gaming desktop computer that beeps continuously when I turn it on so now I have a newer gaming computer but would like to retrieve files from the first computer. How do I do this if the other one doesn't turn on?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Julie Lafountain the easiest would be to remove the storage HDD from computer one and place it in an external USB case. Then you can take it and connect it to computer #2 via USB cable and access the files. We would need to know what HDD is in computer #1 to suggest which external case since it has to match the Hard drive connector. Most likely something like this would work.
Punteggio 0
Aggiungi la tua risposta
Julie Lafountain sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 68
