S20 FE Not charging
S20 fe randomly stopped charging one morning didn’t acknowledge that the charger was plugged in either
Already tried cleaning the port and checking inside for any loose connectors that I could press back into place but no luck
Sent in for repair last Saturday hadn’t heard from them until today and been told the problem is with the motherboard, no info on what actually on the motherboard is the problem but they want to charge me 110 to fix it
Now I was suspicious that the problem lied with the charging module maybe loose connection or something and ordered the part but wanted some advice from others that’ve maybe had the same problem
Thanks
Questa è una buona domanda?
4 Commenti
It seems that the phone has come back with more damage than it went in with and now I believe the phone is truly unfixable
The repair shop has attempted a repair they clearly are not able to do and destroyed any hope of fixing it
da Joseph Ffrench
@joe1605 are you in the uk ?
da daniel
Yes I am. Why?
da Joseph Ffrench
Another update the phone has switched on somehow seems after I switched the charging module it seemed to charge but with the ammeter I can see it’s only drawing 0.09A while switched on but 0.5A while off that’s connected to a plug that should supply 1A
I can also feel the back where they attempted the repair is getting really hot so I suspect a short maybe?
I also suspect it’s a result of the ‘repair’ as it was not doing this before hand
Going back to the shop tomorrow to retrieve the missing screws and mobo shield that was ripped off
Also a suspicious rattle I’m not sure the source of
But will sort all that out tomorrow
da Joseph Ffrench
