Salta al contenuto principale
Rilasciata a novembre 2016, si caratterizza per l'aggiornamento hardware per giocare in 4K e prestazioni PSVR migliorate.
387 Domande Visualizza tutte
My ps4 pro won't boot
my ps4 pro won't turn on, the light bar lights up blue for 1 second then it shuts off instantly no white light or even breathing blue. The Disk drive and fans don't spin. When i try to turn it on for a second time the light bar doesn't light up but the console beeps and it shuts off instantly again
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
So from what I can tell the issue might be with the Power Supply Unit, but I want to eliminate any external factors before encouraging you to swap it out. Make sure that there is nothing wrong with the outlet that your device is plugged into, and ensure that the cable connecting your console to the outlet is not damaged.
Once we make sure that the issue is internal, you can use this guide to swap out the PSU.
Punteggio 1
Aggiungi la tua risposta
sherouzan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 213
