Why my battery is too weak
Questa è una buona domanda?
Hassan morray Koroma the battery is pretty much the only strong point on this phone. You should explain to us what you mean by the battery is weak. If you need to extend your battery life use the suggestions from here The battery life is only as good as you use it. The more you use it the shorter it gets.
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 500
3 Commenti
My battery is so weak
da Dore Mone
Mere mobile ki battery ki life dheere dheere Kam Ho rahi hai
da Md Azad
not charge up properly/long enough
da antonio
