Salta al contenuto principale
Impara a conoscere le competenze di cui potresti aver bisogno per lavorare sul tuo dispositivo.
How to unplug PCB connectors on amp/receiver
Hi
These are the two connector types I want to unplug. Do I need a special tool? I'm used to motherboards but first time with amp/receiver.
Pics included.
Thanks
Update (04/23/2022)
@oldturkey03 here you can see what I mean
Questa è una buona domanda?
Punteggio 1
6 Commenti
@jazzier looks like those are just pull connectors. What make and model is your receiver?
da
@oldturkey03 hi thanks for responding. It's a 1988 Marantz amp/receiver ST110 the sound system user manual is identified as TA110/150. I have another older question pending regarding no display on this receiver. So I know you pull the connectors but how do I unlock them before pulling? I tried and they are very delicate and not much space to manœuvre.
da
@jazzier can't see how they are locked but lets see if I have a manual somewhere for this model.
da
@oldturkey03 pretty sure they have a base to clip into. There are little indents on the sides and on the top picture for the smaller connectors you can see a rectangular portion on one of the wider sides that moves loosely. How do I add picture in a comment?
da
@oldturkey03 look at the picture in an answer here at bottom of page. I tagged you.
da
Mostra 1 altro commento
Aggiungi un commento
1 Risposta
Risposta Più Utile
pull up on the connectors
Punteggio 1
1 Commento:
They have a base.
da
Aggiungi la tua risposta
Jazzy sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 278
