Sadly, other than finding a few loose boards in the wild, finding replacement GPU chips and finding someone with the needed skills and tools won't be easy! The last time I looked I couldn't even find the chip new and I would suspect salvaged chips as likely junk!
I had two of these beauties years ago, each one went through three boards all under warranty! And I even replaced the thermal paste to a better TIM. I used TG Pro a.k.a Temperature Gauge at the time to help control things and still ended up replacing the boards on each twice more paying for it!
I loved these systems! as a photographer it offered me a way to see my digital work out in the field. To be clear I was pushing the system hard as it was not designed to handle the heavy graphics load I was putting on it. I ended up getting 15" Retina's for replacements (Late 2013) and upgraded to DG 2015 models which I will continue to use for the time being. And yes, I still shed a tear as the Intel 16" systems today are just not as useful.
So I have the scars to prove this series had glimmer of hope but Apple & AMD failed us! Apple for not servicing its customers with updated models (MIA: 2012 to 2018) and AMD for shipping a poor quality GPU. I suspect the lack of sales because of the failing GPU's didn't help matters!
Enjoy your now working system! I would strongly get a good thermal monitoring app like TG Pro and if you have the skills repaste the GPU with a good quality TIM but becareful! Many people make a mess using way to much or use a conductive TIM or think liquid metal is better (it will damage your logic board & heat sink). And lastly need your fan and heat sink fin area clean!
And of course don't push this system with heavy GPU tasks.
Votato
Annulla
Punteggio
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
