How can I remove wifi ribbon adhesive from logic board?
I removed the wifi ribbon cable from my 2nd gen ipod touch and it left some adhesive behind, how can i clean the logic board of the adhesive?
Questa è una buona domanda?
You can use some isopropyl alcohol. Use the highest percentage available to you. I would not use the rubbing alcohol, it does have plenty of other stuff in it. Talk to your local pharmacist and see if you can get a 90%. Use a soft toothbrush and carefully scrub the area. Make sure you do not knock of any of the components ;-)
Thanks,
I will give that a try.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 396
