I keep getting error about dirt on anti drop sensor.
I have cleaned the anti drop sensors multiple times but it still keeps giving same error
Questa è una buona domanda?
I sent in my Ecovacs Deebot 950 as I was having this same issue, and apparently the motherboard needs to be replaced
There’s a common failure in this case.
The Ecowacs Ozmo 950 is a vacuum cleaner with the function to wet wipe the floor. This may cause some water on the inner electronic parts. Sometimes this leads to corrosion, shortcuts and further damage. A solution to avoid that problem could be to get some isolation on the circuit boards…
If you are able to solder smd resistors you’ll even be able to repair the motherboard in this case.
First completely disconnect the motherboard. Then you need to measure the resistance of the bigger resistors. There will be at least one resistor which is broken. There are 10 Ohm, 18 Ohm, 30 Ohm and 33 Ohm resistors. The size is “1206”. There are plenty of sample books with 170 different types of 1206 and resistors. Then find a tutorial how to soldering smd resistors and you are good to go fix your motherboard with the anti drop sensor cleaning error.
Make sure to also check the 270 Ohm resistors.
My deebot 950 had no active anti-drop sensors working. On the right side the 30R0 was broken and in the left side the 270. With 2 replacements the bot is functioning again.
U can check the sensors if the bot is turned on with your cellphone camera (ir leds light up).
Some Italian guy on YouTube had more or less the same issue with resistors.
What is core bord issues
Who is Core bord resisters damage ?
Ultime 24 ore: 3
Ultimi 7 giorni: 15
Ultimi 30 giorni: 76
Tutti i Tempi: 2,488
