Salta al contenuto principale
The RipStik Ripster is a smaller and lighter version of the original RipStik.
1 Domande Visualizza tutte
The wheels keep falling off - how to repair?
The axle holding the front wheel to the trucks came out (the bolt that inserts into another bolt apparently unscrewed itself, and the wheel & spacers etc fell out). However, the parts we collected from the road don't appear to make sense together - does anyone have pictures or video showing how to remove and replace the wheels?
Specifically, I need to know what size spacers to order, order of construction, do you need to add LockTite to the bolt, or any other tricks.
I put them back together as well as I could but it didn't look completely right - the wheel was slightly offset to one side (the spaces/washers on either side of the wheel are different lengths!) 2 weeks later the wheel fell off again!
Thanks,
-- Demis
Questa è una buona domanda?
Punteggio 0
1 Commento:
can you post a picture of what you have?
da
Aggiungi un commento
1 Risposta
please see attached links.
one is replacement parts for the ripstick
https://www.ereplacementparts.com/razor-...
and this is a video of the wheel replacement. i hope this helps
https://www.youtube.com/watch?v=UrWy-eli...
EDIT: the wheels probably fell back off because from the pictures on the replacement parts site has loctite blue on the bolt itself to keep it from backing out.
Punteggio 0
Aggiungi la tua risposta
Demis John sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 223
