Salta al contenuto principale
Guides on how to fix and or repair common issues on the 1995-2002 3rd generation Toyota 4Runner. The 3rd generation 4Runner is a body-on-frame truck-based SUV with Independent Front Suspension (IFS) and solid rear axle with coil springs in the front and rear.
16 Domande Visualizza tutte
Why are my rear tires locked all of a sudden?
I'm having the same problem if anyone can answer.. I have a bad wheel barring and the back all of a sudden locked up and you can hear the gears griding when you try and move it.. my mom's boyfriend said I need a new rear end.. is there anything else it could be where I didn't have to buy an entire rear end?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Sorry this isn't the answer but a comment.
I remember from somewhere that the 4Runner has a senser that will normaly engage the locks if the car is in need of extra traction.
If this is so, you might want to look into fix/replacing the senser unit/controller. But first try ungluging the wires to the RR lock switch as this might be faulty.
Punteggio 0
Aggiungi la tua risposta
Ashley Dickinson sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 85
