Salta al contenuto principale
MacBook Pro 15" Airport card replacement
I have a Macbook Pro 15" Unibody 2.53 GHz Mid 2009 (one fan only) rather than a standard Macbook Pro 15" Unibody Mid 2009 (with two fans) and the wifi has stopped working - assume the Airport card has died. There is no guide to fix a Macbook Pro 15" Unibody 2.53 GHz Mid 2009.
I believe the card is located in the centre-back under the black clutch cover. I can probably find a guide to disassemble it eg the one for Macbook Pro 15" Unibody Mid 2009 to access the card and yes it may have some sort of model or identifier on the card once I get it out to be able to order one. But prefer not to disassemble it all before having the replacement part to swap out immediately.
I assume that Macbook Pro 15" Unibody 2.53 GHz Mid 2009 uses the same card as the Macbook Pro 15" Unibody Mid 2009 but does anyone know for sure or have experience with a Macbook Pro 15" Unibody 2.53 GHz Mid 2009 even including Airport card replacement and type?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Here's the needed part MacBook Pro Airport Board (08/09), Apple P/N 661-4766 and follow this guide MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement to get to the WiFi AirPort board which is located in the clutch case (jump to Step 30 in the guide).
Punteggio 1
3 Commenti:
Perfect Dan!! Thanks heaps. Part ordered on ebay. All I have to do is install it.
I've used the Guides before but this is the first time I have needed to use Answers. Really excellent.
Thanks again...
Jay
da
@byronjay - Your Welcome!
da
Hi again Dan... after my modem with the LAN connection stopped working and I am forced for now to use my iPhone hotspot - now nearly a year later I finally got around to installing the wi-fi card - bit of a nightmare - I'm out of practice - but it worked!! Thanks again.
da
Aggiungi la tua risposta
Jay sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 37
