Salta al contenuto principale
The Toshiba Satellite P55W-C5200X was released by Toshiba Corporation in 2016, adding onto the Satellite series.
Can 8gb ram be expanded to 16gb p55w-c5200x
This computer, p55w-c5200X, s/n ZF031585S, has 8gb of ddr3l ram, in two 4gb sticks. Can it be upgraded to 16gb by replacing both sticks with 8gb?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
I did look it up, and you should be able to upgrade to 16 GB of memory. Just be sure that it is the same DDR3L with a speed of 1600MHz. Also 16 GB is going to be your maximum RAM upgrade. Source can be found here
Punteggio 1
Aggiungi la tua risposta
gator.jax.dem sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 125
