Salta al contenuto principale
Dell XPS 2-in-1 laptop computer. Released early 2018, model number 9575.
Usbc ports not working, hardware issue
The usbc ports have one by one stopped working, with the last only functioning at half capacity. Damage appears to be physical- what options are available for repair/replacement? If
Questa è una buona domanda?
Punteggio 1
3 Commenti
Is their any visible damage to the ports, or the actual charger itself?
da
To the charger no, but when I had a tech friend look at it they recognize the physical damage, which could only be from general use
da
And no dirt or debris of any kind?
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
Well, i’m sorry to be the one to tell you this. But unfortunately there’s not an easy way to fix the ports on this device that doesn’t require micro-soldering skills. Thankfully, there are some reputable micro-solderers that troll the forums every once in a while and you can find some of them here.
Punteggio 1
2 Commenti:
Excuse my ignorance, but the soldering is needed to repair them or to swap for a replacement board? It would be enough for me to have them working again on at least one side, but the current issue seems to be finding any place or person that can do the job. I’ll have a look at that link thank you
da
@Jennifer Leo the soldering if for the repair of the ports. The board itself should be fine, it's just the ports.
da
Aggiungi la tua risposta
Jennifer Leo sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 13
Tutti i Tempi: 505
