Nikon D50 built-in flash does not work
The flash does not work. The flash will pop up when shutter button is pressed, however the flash does not fire.
Fix?
Questa è una buona domanda?
Fix?
Stan Keenum, of course your ISO setting is around 400. the flash will not work if your ISO setting is high. I would think that if nothing has happened to your camera and this just came up, that the first thing I check for would be the main condenser and the wiring to the DC-DC board. Also check the popup switch. You can download the service manual for your camera from here
I have a bad flash on my D50, can you please share the service manual again for it? Thanks.
You can Try it now
Thank You!
Bill, try it now
Hi, i cant access the manual, could u please share again
Many Thanks
Matt
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 3,606
