Salta al contenuto principale
The RIM BlackBerry Curve 8520 is a sleek entry-level smartphone that delivers some nice design enhancements and great performance
30 Domande Visualizza tutte
screen still white after replacement
help!! ive replaced my blackberry curve 8520 screen after it being dropped and cracked but now all i get is a blank white screen ive tried disconnecting and reconnecting a few times but no luck.
thanks
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
dirtydaz, check on here and look for the answer provided by JSanders. Give that a try and see if it makes a difference. If that does not work, you may have to double check your work and make sure all connections are properly made. The BB bold uses some filters on the logic board, that when faulty, cause the same problem. So you may have to use a multimeter and see if you have continuity on those.
Punteggio 3
Aggiungi la tua risposta
dirtydaz sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 3,856
