Salta al contenuto principale
Processore dual core Intel i7 da 2,2 GHz (Turbo Boost fino a 3,1 GHz) o quad core Intel Core i7 da 2,5 GHz (Turbo Boost fino a 3,7 GHz) con 6 MB di cache L3 condivisa.
467 Domande Visualizza tutte
Failure to boot after battery replacement - MacBook Pro 15" Retina
I have replaced the original battery. The laptop booted as soon as I connected the power supply. I was able to log in and briefly, not extensively verify that my MacBook was operating properly. Knowing I had to charge the new battery to 100%, I shut down and left the Mac charging overnight. In the morning, the MagSafe light was solid green, suggesting that battery had charged . However, the laptop refused to boot, with or without the power connected.
I reset SMC, which seems to be working by the blinking MagSafe green light. I disconnected the battery, reset power management, hoping to run off the power supply, all to no avail.
I have read lots of similar questions on this forum but nothing seems to fit my case. I’m at my wit’s end.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Let’s give this a try, disconnect the battery again with nothing plugged in press and hold the power button for a good 15 secs. to allow the logic board to fully discharge. Now carefully plug in the MagSafe charger leaving the battery still disconnected. Press the power button did your system boot up? If it did, carefully shut it down properly.
Punteggio 0
2 Commenti:
Hi. I also have the exact same problem. Tried the suggestion but still no joy. Really at a loss and wishing I hadn't changed out the battery now! Any help MUCH appreciated! Thanks
da
@paulk1975 - are you going to keep me guessing… And what happened? Did your system bootup?
da
Aggiungi la tua risposta
Andrei Zhitkov sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 97
