Salta al contenuto principale
La versione allargata del decimo telefono di Samsung della sua serie top S, presentato nel febbraio 2019. Dotato di Android 9.0 (Pie).
20 Domande Visualizza tutte
No image after battery replacement, Help?
Let’s see how to explain this… Had a swollen battery, replaced it according to the guide, I think I used too much alcohol so my cameras, front and back got foggy, after replacing the battery the phone worked fine, it charges and I could see use the phone. I left it charging and a few minutes later checked the cameras again and there was condensation on the back cameras again so I removed the back cover to clean and left it open while wireless charging so all the alcohol would evaporate… now I have no image, the phone keeps working, and I get the haptic feedback when trying to unlock with my thumb, but I can’t turn it off and I really don’t want to buy a %#*@ screen after having to buy a new battery.
I will leave it charging and hope it’s just the alcohol messing around and hope it evaporates and it’s fixed.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
try holding the power button for 10+ seconds to force restart, if still nothing, unplug and replug battery and check for life, disconnect and reconnect the screen connector and check. after you installed the battery and back you had a working display that then stopped working or did you not test display after connecting the new battery?
Punteggio 0
Aggiungi la tua risposta
Brian sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 173
