Salta al contenuto principale
Il Samsung Galaxy A10 è uno smartphone android di fascia media sviluppato da Samsung Electronics, che l'ha lanciato a marzo 2019.
My Samsung phone won't let me call out
I can't make it receive calls on my Samsung phone but I can still text and use internet what do I do
Tried turning it off n back on n tried airplane mode on and off but nothing works to get the calling option to work texting n internet are working fine though
Questa è una buona domanda?
Punteggio 0
1 Commento
I can not make calls on my Samsung S10. I can receive calls and send text messages but I cannot make outgoing calls
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi,
Try the following and check if it works OK or not.
i). Wipe the cache partition and check if it works.
ii). Start the phone in safe mode and check if it works OK.
If it does then a downloaded app is the cause of the problem. You will need to uninstall each downloaded app one by one and test the phone in normal mode to see if it works OK. When it does then the last downloaded app that was uninstalled was the culprit. A downloaded app is one that you downloaded and installed on the phone and wasn’t pre-installed when you first got it.
Punteggio 1
Aggiungi la tua risposta
Christina Collins sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 9
Tutti i Tempi: 2,946
