Salta al contenuto principale
The Samsung Galaxy Tab A 10.1 is known by different models depending on the features. Regular model: SM-T580 (WiFi), SM-T585 (3G,4G/LTE and WiFi) released in May 2016 or S-Pen model: SM-P580 (WiFi), SM-P585 (3G,4G/LTE and WiFi) released in September 2016. It is a 10.1- inch tablet manufactured by Samsung Electronics and their new high-end “A” series.
108 Domande Visualizza tutte
Problem with charging my tablet, but connection to PC is good
Hello,
so for some reason today my tablet (T580 model one), stopped charging it. Tried with different cable, adapter, wall outlet, safe mode, and even complete reset of it. Tried the same with another phone and works fine. Connected my tablet to the PC and the PC detects it and can transfer files (same USB cable I use for charging) so it’s not a charging port problem. Either it’s a battery or software problem. For some reason when I tried to turn off the tablet while it was charging it, it went to Download/Odin mode every time. Don’t know why, but it literally worked yesterday and didn’t do anything that would cause such a problem.
Can anyone help? Did anybody have such an experience?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Soluzione Prescelta
Sent to official customer service of Samsung a few days ago, basically, they told me it was a problem with charging port and they fixed it quickly
Punteggio 0
Risposta Più Utile
Ontop of oldturkeys suggestions of fuel guage.
You may have faulty/worn pin on the charging port of the device, as different pins are used for data transfer.
After that, looking at charging IC circuit, or filters within that circuit which have popped.
Punteggio 1
@jukanida to rule out a software issue I would do a reset. Of course, safe all your files etc. first in a backup since you will lose those. After that try this Come ripristinare ai dati di fabbrica il Galaxy Tab A 10.1
Let us know what you get and if it worked. If not, time to take your tablet apart and have a closer look at the charging circuitry etc.
Punteggio 0
2 Commenti:
Doesn't work. I already said that I made complete reset. That didn't do anything. Also, I charged approximately 45 min even though it wasn't showing any info of charging and after that I unplugged it and 15 min later noticed that percentage went from 12% to 20% (tablet unplugged ). Weird. Wouldn't proclaim it as a solution
da
@jukanida Is this still the original battery? With the symptoms you describe I wonder if this is an issue with the fuel gauge circuitry on the battery.
da
Aggiungi la tua risposta
Jukanida sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 148
