Salta al contenuto principale
Lanciato a novembre 2020, il MacBook Pro da 13" ha il SoC basato su ARM M1 di Apple con una CPU octacore e una GPU octacore. (Modello A2338 / EMC 3578 con due porte Thunderbolt 3)
112 Domande Visualizza tutte
How do I remove the fingerprint scanner
I spilled coffee on the keyboard and I have been able to successfully remove and clean all the keys except the fingerprint scanner/ power switch. Is there any way I can open it and clean it ?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
The power switch and TouchID sensor is very delicate! IF you damage it thats the end of not only the button but the logic board which it is married too.
The assembly is held from the inside by a set of screws. Its a fair amount of work to even get to so unless you have some experience taking your system apart I would leave it be or bring your system to an authorized Apple repair shop as they have deeper skills.
Punteggio 0
Aggiungi la tua risposta
allen pradhan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 28
Tutti i Tempi: 323
