MacBook Pro 2015 A1398 i7-4770HQ R9 M370X screen flickering
Hello,
Recently my retina display started flickering. It happening randomly, seems like the display is not synchronizing. Usually after 2 minutes after the startup. This issue is only present on the Retina display, on external monitor, everything is fine.
I want to point out that I didn't drop or hit the MacBook, this suddenly happened when I was web browsing.
I did already try first to unplug LVDS cable and plug it back, but it didn't work. So I decided to replace LVDS cable but it also didn't work.
I did upgrade to Monterey and then downgraded to High Sierra, the issue is still present. Since there is no physical damage to hardware, I would say it is something wrong with power management/drivers?
I read somewhere that the dust could cause this after some years, but I cleaned it and the LVDS cable stick to the connector just like factory made.
I did run diagnostic mode (Power + D on startup) and no issues found.
I noticed that sometimes when I put device in sleep and wake up it helps but this issue flickering is present after few minutes.
The MacBook is out of warranty, replacement of display/gpu cost the same amount of other used MB PRO from this year. Any thoughts what else can I do? Try with different LVDS cable?
Best Regards,
Questa è una buona domanda?
