Salta al contenuto principale
Processore quad core Intel Core i7 da 2,2 GHz (3,4 GHz con Turbo boost), 2,5 GHz (fino a 3,7 GHz con Turbo boost) o 2,8 GHz (fino a 4,0 GHz con Turbo boost) con 6 MB di cache L3 condivisa.
2013 and 2015 screen compatibility
hello, I recently acquired a 2015 MacBook pro for cheap. it had no ssd or charger and a damaged screen. I currently have also a 2013 MacBook pro with a screen that works properly, could I use the screen from my 2013 and install it on the 2015? both are 15” retina displays
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Sorry you can’t, the displays between these series use different signaling. While both are similar in its connections the 2013 uses iDP while the 2015 uses eDP signaling.
You’ll need to use the correct display MacBook Pro 15" Retina (Mid 2015) Display Assembly
Immagine Replace a display compatible with themodel A1398 Mid 2015 15" MacBook Pro laptop. Includes the 2880 x 1800 15.4" Retina LCD screen, display cover, bezel, FaceTime HD Camera, clutch hinges, Wi-Fi antenna, camera, and display data cables.
Prodotto
$519.99
Punteggio 3
8 Commenti:
I did the same thing. Is that why the screen is so dark. (I have to use the flashlight to see the screen) everything else works fine.
da
@benjicost - Hopefully you didn't damage things!
da
Guess ill see when the new screen arrives. Otherwise what could be the problem ?
da
@benjicost - The pinout for power is different between the series.
da
Can you explain more ? (I dont understand what that means)
da
Mostra altri 3 commenti
Aggiungi la tua risposta
abel leu sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 22
Tutti i Tempi: 1,791
